pebble
  • Tutorials
  • Get the SDK
  • Guides
  • Documentation
  • Examples
  • Community
  • Blog
  • More
Privacy
Cookies
Publish
Tutorials
    • Part 4 - Adding Weather
    • Part 5 - Timeline Peek
    • Part 6 - User Settings
  • Build a Watchface in C
  • Advanced Tutorials
    • Vector Animations
Adding Web Content to a Rocky.js JavaScript Watchface (Archived)
Device Compatibility
Rocky.js requires Pebble OS v4.x and therefore will not support Pebble Classic or Pebble Steel.
Note: We're working on a brand new JavaScript runtime for Pebble! The previous Rocky.js implementation is being replaced with Moddable, a modern open-source JavaScript engine that will bring enhanced capabilities to Pebble development. Moddable will enable developers to write apps that blend C and JavaScript with a more full-featured runtime and SDK. Learn more about our plans in this blog post. This tutorial is archived for reference but may not work with future SDK versions.
rocky
We'll be using the JavaScript component pkjs, which runs on the user's mobile device using PebbleKit JS. This pkjs component can be used to access information from the Internet and process it on the phone. This pkjs environment does not have the same the hardware and memory constraints of the Pebble.
First Steps
The first thing we'll need to do is edit a file from the project we created in Part 1. The file is called /src/pkjs/index.js and it is the entry point for the pkjs portion of the application.
This pkjs component of our application is capable of sending and receiving messages with the smartwatch, accessing the user's location, making web requests, and an assortment of other tasks that are all documented in the PebbleKit JS documentation.
Although Rocky.js (watch) and pkjs (phone) both use JavaScript, they have separate APIs and purposes. It is important to understand the differences and not attempt to run your code within the wrong component.
Sending and Receiving Messages
Before we get onto the example, it's important to understand how to send and receive messages between the Rocky.js component on the smartwatch, and the pkjs component on the mobile device.
Sending Messages
To send a message from the smartwatch to the mobile device, use the rocky.postMessage method, which allows you to send an arbitrary JSON object:
// rocky index.js
var rocky = require('rocky');
// Send a message from the smartwatch
rocky.postMessage({'test': 'hello from smartwatch'});
To send a message from the mobile device to the smartwatch, use the Pebble.postMessage method:
// pkjs index.js
// Send a message from the mobile device
Pebble.postMessage({'test': 'hello from mobile device'});
Message Listeners
We can create a message listener in our smartwatch code using the rocky.on method:
// rocky index.js
// On the smartwatch, begin listening for a message from the mobile device
rocky.on('message', function(event) {
  // Get the message that was passed
  console.log(JSON.stringify(event.data));
We can also create a message listener in our pkjs code using the Pebble.on method:
// pkjs index.js
// On the phone, begin listening for a message from the smartwatch
Pebble.on('message', function(event) {
Requesting Location
Our pkjs component can access to the location of the user's smartphone. The Rocky.js component cannot access location information directly, it must request it from pkjs.
In order to use this functionality, your application must include the location flag in the pebble.capabilities array of your package.json file.
// file: package.json
  "pebble": {
    "capabilities": ["location"]
Once we've added the location flag, we can access GPS coordinates using the Geolocation API. In this example, we're going to request the user's location when we receive the "fetch" message from the smartwatch.
// pkjs index.js
  var message = event.data;
  if (message.fetch) {
    navigator.geolocation.getCurrentPosition(function(pos) {
      // TODO: fetch weather
    }, function(err) {
      console.error('Error getting location');
    { timeout: 15000, maximumAge: 60000 });
Web Service Calls
The pkjs side of our application can also access the XMLHttpRequest object. Using this object, developers are able to interact with external web services.
In this tutorial, we will interface with Open Weather Map – a common weather API used by the Pebble Developer Community.
The XMLHttpRequest object is quite powerful, but can be intimidating to get started with. To make things a bit simpler, we'll wrap the object with a helper function which makes the request, then raises a callback:
// pkjs index.js
function request(url, type, callback) {
  var xhr = new XMLHttpRequest();
  xhr.onload = function () {
    callback(this.responseText);
  xhr.open(type, url);
  xhr.send();
The three arguments we have to provide when calling our request() method are the URL, the type of request (GET or POST) and a callback for when the response is received.
Fetching Weather Data
The URL is specified on the OpenWeatherMap API page, and contains the coordinates supplied by getCurrentPosition() (latitude and longitude), followed by the API key:
API KEY REQUIRED
As of October 2015, an API key is required to fetch OpenWeatherMap data. These can be freely obtained from OpenWeatherMap.org.
var myAPIKey = '1234567';
var url = 'http://api.openweathermap.org/data/2.5/weather' +
          '?lat=' + pos.coords.latitude +
          '&lon=' + pos.coords.longitude +
          '&appid=' + myAPIKey;
All together, our message handler should now look like the following:
// pkjs index.js
      request(url, 'GET', function(respText) {
        var weatherData = JSON.parse(respText);
        //TODO: Send weather to smartwatch
    }, function(err) {
Finishing Up
Once we receive the weather data from OpenWeatherMap, we need to send it to the smartwatch using Pebble.postMessage:
// pkjs index.js
    'weather': {
      // Convert from Kelvin
      'celcius': Math.round(weatherData.main.temp - 273.15),
      'fahrenheit': Math.round((weatherData.main.temp - 273.15) * 9 / 5 + 32),
      'desc': weatherData.weather[0].main
On the smartwatch, we'll need to create a message handler to listen for a weather message, and store the information so it can be drawn on screen.
// rocky index.js
// Global object to store weather data
var weather;
  // Receive a message from the mobile device (pkjs)
  if (message.weather) {
    // Save the weather data
    weather = message.weather;
    // Request a redraw so we see the information
    rocky.requestDraw();
We also need to send the 'fetch' command from the smartwatch to ask for weather data when the application starts, then every hour:
// rocky index.js
rocky.on('hourchange', function(event) {
  // Send a message to fetch the weather information (on startup and every hour)
  rocky.postMessage({'fetch': true});
Finally, we'll need some new code in our Rocky draw handler to display the temperature and conditions:
// rocky index.js
function drawWeather(ctx, weather) {
  // Create a string describing the weather
  //var weatherString = weather.celcius + 'ºC, ' + weather.desc;
  var weatherString = weather.fahrenheit + 'ºF, ' + weather.desc;
  // Draw the text, top center
  ctx.fillStyle = 'lightgray';
  ctx.textAlign = 'center';
  ctx.font = '14px Gothic';
  ctx.fillText(weatherString, ctx.canvas.unobstructedWidth / 2, 2);
rocky.on('draw', function(event) {
  var ctx = event.context;
  var d = new Date();
  // Clear the screen
  ctx.clearRect(0, 0, ctx.canvas.clientWidth, ctx.canvas.clientHeight);
  // Draw the conditions (before clock hands, so it's drawn underneath them)
  if (weather) {
    drawWeather(ctx, weather);
Conclusion
So there we have it, we successfully added web content to our JavaScript watchface! To do this we:
  1. Enabled location in our package.json.
  2. Added a Pebble.on('message', function() {...}); listener in pkjs.
  3. Retrieved the users current GPS coordinates in pkjs.
  4. Used XMLHttpRequest to query OpenWeatherMap API.
  5. Sent the current weather conditions from the mobile device, to the smartwatch, using Pebble.postMessage().
  6. On the smartwatch, we created a rocky.on('message', function() {...}); listener to receive the weather data from pkjs.
  7. We subscribed to the hourchange event, to send a message to pkjs to request the weather data when the application starts and every hour.
  8. Then finally we drew the weather conditions on the screen as text.
If you have problems with your code, check it against the sample source code provided using the button below.
View Source Code
What's Next
We hope you enjoyed this tutorial and that it inspires you to make something awesome!
Why not let us know what you've created by tweeting @pebbledev, or join our epic developer community on Discord.
Overview
  • First Steps
  • Sending and Receiving Messages
  • Sending Messages
  • Message Listeners
  • Requesting Location
  • Web Service Calls
  • Fetching Weather Data
  • Finishing Up
  • Conclusion
  • What's Next
