pebble
  • Tutorials
  • Get the SDK
  • Guides
  • Documentation
  • Examples
  • Community
  • Blog
  • More
Privacy
Cookies
Publish
Tutorials
    • Part 4 - Adding Weather
    • Part 5 - Timeline Peek
    • Part 6 - User Settings
  • Build a Watchface in C
  • Advanced Tutorials
    • Vector Animations
Build a Watchface in JavaScript using Rocky.js (Archived)
Device Compatibility
Rocky.js requires Pebble OS v4.x and therefore will not support Pebble Classic or Pebble Steel.
Note: We're working on a brand new JavaScript runtime for Pebble! The previous Rocky.js implementation is being replaced with Moddable, a modern open-source JavaScript engine that will bring enhanced capabilities to Pebble development. Moddable will enable developers to write apps that blend C and JavaScript with a more full-featured runtime and SDK. Learn more about our plans in this blog post. This tutorial is archived for reference but may not work with future SDK versions.
We're going to start with some basics, then create a simple digital watchface and finally create an analog clock which looks just like this:
rocky
First Steps
If you haven't already, head over the SDK Page to learn how to download and install the latest version of the Pebble Tool, and the latest SDK.
Once you've installed the Pebble Tool and SDK 4.0, you can create a new Rocky.js project with the following command:
$ pebble new-project --rocky helloworld
This will create a new folder called helloworld and populate it with the basic structure required for a basic Rocky.js application.
Watchface Basics
Watchface are essentially long running applications that update the display at a regular interval (typically once a minute, or when specific events occur). By minimizing the frequency that the screen is updated, we help to conserve battery life on the watch.
The main entry point for the watchface is /src/rocky/index.js, so we'll start by editing this file.
The very first thing we must do is include the Rocky.js library, which gives us access to the APIs we need to create a Pebble watchface.
var rocky = require('rocky');
Next, the invocation of rocky.on('minutechange', ...) registers a callback method to the minutechange event - which is emitted every time the internal clock's minute changes (and also when the handler is registered). Watchfaces should invoke the requestDraw method as part of the minutechange event to redraw the screen.
rocky.on('minutechange', function(event) {
  rocky.requestDraw();
NOTE: Watchfaces that need to update more or less frequently can also register the secondchange, hourchange or daychange events.
Next we register a callback method to the draw event - which is emitted after each call to rocky.requestDraw(). The event parameter passed into the callback function includes a CanvasRenderingContext2D object, which is used to determine the display characteristics and draw text or shapes on the display.
rocky.on('draw', function(event) {
  // Get the CanvasRenderingContext2D object
  var ctx = event.context;
The RockyDrawCallback is where we render the smartwatch display, using the methods provided to us through the CanvasRenderingContext2D object.
NOTE: The draw event may also be emitted at other times, such as when the handler is first registered.
Creating a Digital Watchface
In order to create a simple digital watchface, we will need to do the following things:
  • Subscribe to the minutechange event.
  • Subscribe to the draw event, so we can update the display.
  • Clear the display each time we draw on the screen.
  • Determine the width and height of the available content area of the screen.
  • Obtain the current date and time.
  • Set the text color to white.
  • Center align the text.
  • Display the current time, using the width and height to determine the center point of the screen.
To create our minimal watchface which displays the current time, let's replace the contents of /src/rocky/index.js with the following code:
  // Clear the screen
  ctx.clearRect(0, 0, ctx.canvas.clientWidth, ctx.canvas.clientHeight);
  // Determine the width and height of the display
  var w = ctx.canvas.unobstructedWidth;
  var h = ctx.canvas.unobstructedHeight;
  // Current date/time
  var d = new Date();
  // Set the text color
  ctx.fillStyle = 'white';
  // Center align the text
  ctx.textAlign = 'center';
  // Display the time, in the middle of the screen
  ctx.fillText(d.toLocaleTimeString(), w / 2, h / 2, w);
  // Display a message in the system logs
  console.log("Another minute with your Pebble!");
  // Request the screen to be redrawn on next pass
First Compilation and Installation
To compile the watchface, make sure you have saved your project files, then run the following command from the project's root directory:
$ pebble build
After a successful compilation you will see a message reading 'build' finished successfully.
If there are any problems with your code, the compiler will tell you which lines contain an error, so you can fix them. See Troubleshooting and Debugging for further information.
Now install the watchapp and view the logs on the emulator by running:
$ pebble install --logs --emulator basalt
Congratulations!
You should see a loading bar as the watchface is loaded, shortly followed by your watchface running in the emulator.
rocky
Your logs should also be displaying the message we told it to log with console.log().
Note: You should prevent execution of the log statements by commenting the code, if you aren't using them. e.g. //console.log();
Creating an Analog Watchface
In order to draw an analog watchface, we will need to do the following things:
  • Use the width and height to determine the center point of the screen.
  • Calculate the max length of the watch hands based on the available space.
  • Determine the correct angle for minutes and hours.
  • Draw the minute and hour hands, outwards from the center point.
Drawing the Hands
We're going to need to draw two lines, one representing the hour hand, and one representing the minute hand.
We need to implement a function to draw the hands, to prevent duplicating the same drawing code for hours and minutes. We're going to use a series of CanvasRenderingContext2D methods to accomplish the desired effect.
First we need to find the center point in our display:
// Determine the available width and height of the display
// Determine the center point of the display
var cx = w / 2;
var cy = h / 2;
Now we know the starting point for the hands (cx, cy), but we still need to determine the end point. We can do this with a tiny bit of math:
var x2 = cx + Math.sin(angle) * length;
var y2 = cy - Math.cos(angle) * length;
Then we'll use the ctx parameter and configure the line width and color of the hand.
// Configure how we want to draw the hand
ctx.lineWidth = 8;
ctx.strokeStyle = color;
Finally we draw the hand, starting from the center of the screen, drawing a straight line outwards.
// Begin drawing
ctx.beginPath();
// Move to the center point, then draw the line
ctx.moveTo(cx, cy);
ctx.lineTo(x2, y2);
// Stroke the line (output to display)
ctx.stroke();
Putting It All Together
function fractionToRadian(fraction) {
  return fraction * 2 * Math.PI;
function drawHand(ctx, cx, cy, angle, length, color) {
  // Find the end points
  ctx.lineWidth = 8;
  // Begin drawing
  ctx.beginPath();
  ctx.moveTo(cx, cy);
  ctx.lineTo(x2, y2);
  ctx.stroke();
  var d = new Date();
  // Clear the screen
  // and the max size of watch hands
  var cx = w / 2;
  var cy = h / 2;
  // -20 so we're inset 10px on each side
  var maxLength = (Math.min(w, h) - 20) / 2;
  // Calculate the minute hand angle
  var minuteFraction = (d.getMinutes()) / 60;
  var minuteAngle = fractionToRadian(minuteFraction);
  // Draw the minute hand
  drawHand(ctx, cx, cy, minuteAngle, maxLength, "white");
  // Calculate the hour hand angle
  var hourFraction = (d.getHours() % 12 + minuteFraction) / 12;
  var hourAngle = fractionToRadian(hourFraction);
  // Draw the hour hand
  drawHand(ctx, cx, cy, hourAngle, maxLength * 0.6, "lightblue");
Now compile and run your project in the emulator to see the results!
If your build didn't work, you'll see the error message: Build Failed. Let's take a look at some of the common types of errors:
Rocky.js Linter
As part of the build process, your Rocky index.js file is automatically checked for errors using a process called 'linting'.
The first thing to check is the 'Lint Results' section of the build output.
========== Lint Results: index.js ==========
src/rocky/index.js(7,39): error TS1005: ',' expected.
src/rocky/index.js(9,8): error TS1005: ':' expected.
src/rocky/index.js(9,37): error TS1005: ',' expected.
src/rocky/index.js(7,1): warning TS2346: Supplied parameters do not match any signature of call target.
src/rocky/index.js(7,24): warning TS2304: Cannot find name 'funtion'.
Errors: 3, Warnings: 2
Please fix the issues marked with 'error' above.
In the error messages above, we see the filename which contains the error, followed by the line number and column number where the error occurs. For example:
Filename: src/rocky/index.js
Line number: 7
Character: 24
Description: Cannot find name 'funtion'.
rocky.on('minutechange', funtion(event) {
As we can see, this error relates to a typo, 'funtion' should be 'function'. Once this error has been fixed and you run pebble build again, you should see:
Everything looks AWESOME!
Locating Errors Using Logging
So what do we do when the build is successful, but our code isn't functioning as expected? Logging!
Scatter a breadcrumb trail through your application code, that you can follow as your application is running. This will help to narrow down the location of the problem.
  console.log('minutechange fired!');
Once you've added your logging statements, rebuild the application and view the logs:
$ pebble build && pebble install --emulator basalt --logs
If you find that one of your logging statements hasn't appeared in the log output, it probably means there is an issue in the preceding code.
I'm still having problems!
If you've tried the steps above and you're still having problems, there are plenty of places to get help. You can post your question and code on the Pebble Forums or join our Discord Server and ask for assistance.
Conclusion
So there we have it, the basic process required to create a brand new Pebble watchface using JavaScript! To do this we:
  1. Created a new Rocky.js project.
  2. Included the 'rocky' library.
  3. Subscribed to the minutechange event.
  4. Subscribed to the draw event.
  5. Used drawing commands to draw text and lines on the display.
If you have problems with your code, check it against the sample source code provided using the button below.
View Source Code
What's Next
If you successfully built and run your application, you should have seen a very basic watchface that closely mimics the built-in TicToc. In the next tutorial, we'll use postMessage to pass information to the mobile device, and request weather data from the web.
Go to Part 2 →
Overview
  • First Steps
  • Watchface Basics
  • Creating a Digital Watchface
  • First Compilation and Installation
  • Congratulations!
  • Creating an Analog Watchface
  • Drawing the Hands
  • Putting It All Together
  • Troubleshooting and Debugging
  • Rocky.js Linter
  • Locating Errors Using Logging
  • I'm still having problems!
  • Conclusion
  • What's Next
