The finishing touch for any great watchface is letting users make it their own.
In this final part we will add user settings using localStorage - a simple
key-value store built right into Alloy - and then add a phone-side configuration
page using Clay for Pebble so users can
change settings from their phone. Users will be able to choose background
and text colors, toggle the date display, pick temperature units, and choose
between 12-hour and 24-hour time formats.
Here is an example of a customized watchface:
This section continues from Part 5.
Alloy provides the standard Web localStorage API for persistent storage.
Data is saved to flash and survives app restarts. The API is straightforward:
localStorage.setItem(key, value) - store a string valuelocalStorage.getItem(key) - retrieve a value (or null if missing)localStorage.removeItem(key) - delete a valueSince localStorage only stores strings, we use JSON.stringify() and
JSON.parse() to store structured data like our settings object.
Add a defaults object near the top of main.js, after the font declarations:
const DEFAULT_SETTINGS = {
backgroundColor: { r: 0, g: 0, b: 0 },
textColor: { r: 255, g: 255, b: 255 },
useFahrenheit: false,
showDate: true,
use24Hour: true
We store colors as { r, g, b } objects so they serialize cleanly to JSON.
Add two helper functions:
function loadSettings() {
const stored = localStorage.getItem("settings");
if (stored) {
try {
return { ...DEFAULT_SETTINGS, ...JSON.parse(stored) };
} catch (e) {
console.log("Failed to parse settings");
return { ...DEFAULT_SETTINGS };
function saveSettings() {
localStorage.setItem("settings", JSON.stringify(settings));
let settings = loadSettings();
The spread pattern { ...DEFAULT_SETTINGS, ...JSON.parse(stored) } is
important. It ensures that if we add new settings in a future version, they
automatically get default values even when loading old saved data. This is the
Alloy equivalent of the C pattern of calling prv_default_settings() before
persist_read_data().
Replace the hardcoded black and white color declarations with
settings-driven ones:
let bgColor = render.makeColor(settings.backgroundColor.r,
settings.backgroundColor.g, settings.backgroundColor.b);
let textColor = render.makeColor(settings.textColor.r,
settings.textColor.g, settings.textColor.b);
function updateColors() {
The updateColors() function recreates the Poco color values whenever settings
change. Call it after loading new settings.
Update drawScreen() to use the settings-driven colors and respect the
showDate toggle:
function drawScreen(event) {
const now = event?.date ?? lastDate;
if (event?.date) lastDate = event.date;
render.begin();
render.fillRectangle(bgColor, 0, 0, render.width, render.height);
// ... battery bar and disconnect indicator ...
// Format time as HH:MM (24h) or H:MM (12h)
let hours = now.getHours();
if (!settings.use24Hour) {
hours = hours % 12 || 12;
const hoursStr = String(hours).padStart(2, "0");
const minutes = String(now.getMinutes()).padStart(2, "0");
const timeStr = `${hoursStr}:${minutes}`;
// Draw time
let width = render.getTextWidth(timeStr, timeFont);
render.drawText(timeStr, timeFont, textColor,
(render.width - width) / 2, timeY);
// Draw date if setting is enabled
if (settings.showDate) {
// ... date drawing code ...
render.drawText(dateStr, dateFont, textColor,
(render.width - width) / 2, dateY);
// ... weather display ...
render.end();
The key changes:
- bgColor replaces black for the background fill
- textColor replaces white for all text drawing
- The date block is wrapped in if (settings.showDate)
- Time formatting respects the use24Hour setting - when disabled, hours are
converted to 12-hour format using hours % 12 || 12 (the || 12 turns
midnight's 0 into 12)
Also update the battery bar border to use textColor instead of hardcoded
white, so it matches the user's color choice:
function drawBatteryBar() {
render.fillRectangle(textColor, barX, barY, barWidth, barHeight);
render.fillRectangle(bgColor, barX + 1, barY + 1, barWidth - 2, barHeight - 2);
Update the weather display to show the correct unit:
if (weather) {
const unit = settings.useFahrenheit ? "F" : "C";
const weatherStr = `${weather.temp}°${unit} ${weather.conditions}`;
In fetchWeather(), pass the unit preference to Open-Meteo so the API returns
the temperature in the correct unit directly:
async function fetchWeather(latitude, longitude) {
const params = {
latitude,
longitude,
current: "temperature_2m,weather_code"
if (settings.useFahrenheit) {
params.temperature_unit = "fahrenheit";
const url = new URL("https://api.open-meteo.com/v1/forecast");
url.search = new URLSearchParams(params);
Open-Meteo supports a temperature_unit parameter natively, so we do not need
to convert on the watch - the API handles it for us.
Since weather data is expensive to fetch (it requires a phone connection and
network request), we cache it in localStorage so the watchface can show
recent weather immediately on startup:
function loadCachedWeather() {
const cached = localStorage.getItem("weather");
const cachedTime = localStorage.getItem("weatherTime");
if (cached && cachedTime) {
const age = Date.now() - Number(cachedTime);
// Use cache if less than 1 hour old
if (age < 60 * 60 * 1000) {
try {
weather = JSON.parse(cached);
console.log("Using cached weather");
return true;
} catch (e) {
console.log("Failed to parse cached weather");
return false;
function saveWeather() {
if (weather) {
localStorage.setItem("weather", JSON.stringify(weather));
localStorage.setItem("weatherTime", String(Date.now()));
Call loadCachedWeather() at startup, and call saveWeather() at the end of
a successful fetchWeather():
// At module level
loadCachedWeather();
// Inside fetchWeather(), after setting weather:
saveWeather();
drawScreen();
This gives users instant weather display on app launch instead of "Loading..." while waiting for the phone connection and API response.
So far our settings only have default values and no way for the user to change them. Let's add a phone-side configuration page using Clay for Pebble. Clay generates a settings UI on the phone from a simple JSON definition and sends the values to the watch via AppMessage - the same mechanism used by the C tutorial.
In CloudPebble, go to the Packages section in the left sidebar and add
@rebble/clay.
Clay is available as a Pebble Package. Install it from your project directory:
$ pebble package install @rebble/clay
This adds @rebble/clay to the dependencies in package.json.
In CloudPebble, go to Settings and add configurable to the
Capabilities list so the gear icon appears next to your watchface in the
phone app.
For the gear icon to appear next to your watchface in the phone app, add
configurable to the capabilities array in package.json:
"capabilities": [
"location",
"configurable"
In CloudPebble, go to Settings and add the following message keys in the
PebbleKit JS Message Keys section: BackgroundColor, TextColor,
TemperatureUnit, ShowDate, and HourFormat.
Clay sends settings to the watch as AppMessage key-value pairs. Add message
keys for each setting to package.json:
"messageKeys": [
"BackgroundColor",
"TextColor",
"TemperatureUnit",
"ShowDate",
"HourFormat"
These keys are used by Clay in the PKJS layer and by the Message class on the
watch to identify which setting is being sent.
Click Add New next to Source Files, select JavaScript file, and
name it config.js. Clay uses a simple JSON array of sections and fields:
Create src/pkjs/config.js with the configuration definition. Clay uses a
module.exports = [
"type": "heading",
"defaultValue": "Watchface Settings"
"type": "text",
"defaultValue": "Customize your watchface appearance and preferences."
"type": "section",
"items": [
"type": "heading",
"defaultValue": "Colors"
"type": "color",
"messageKey": "BackgroundColor",
"defaultValue": "0x000000",
"label": "Background Color"
"type": "color",
"messageKey": "TextColor",
"defaultValue": "0xFFFFFF",
"label": "Text Color"
"type": "section",
"items": [
"type": "heading",
"defaultValue": "Preferences"
"type": "toggle",
"messageKey": "TemperatureUnit",
"label": "Use Fahrenheit",
"defaultValue": false
"type": "toggle",
"messageKey": "ShowDate",
"label": "Show Date",
"defaultValue": true
"type": "toggle",
"messageKey": "HourFormat",
"label": "Use 24-Hour Format",
"type": "submit",
"defaultValue": "Save Settings"
This is the same configuration used in the C tutorial. Each messageKey
matches a key in package.json. The color type provides a color picker and
toggle gives a switch.
Open your JavaScript file in the CloudPebble editor and initialize Clay before the proxy:
Update src/pkjs/index.js to initialize Clay before the proxy:
var Clay = require('@rebble/clay');
var clayConfig = require('./config');
var clay = new Clay(clayConfig);
const moddableProxy = require("@moddable/pebbleproxy");
Pebble.addEventListener('ready', moddableProxy.readyReceived);
Pebble.addEventListener('appmessage', moddableProxy.appMessageReceived);
Clay automatically handles the showConfiguration and webviewClosed events
(opening the settings page and sending results back). The proxy continues to
handle ready and appmessage for fetch and location requests from the watch.
There is no conflict since they use different event types.
When the user saves settings on the phone, Clay sends them as an AppMessage.
On the watch side, we use the Message class from pebble/message to receive
them. Add the import at the top of main.js:
import Message from "pebble/message";
Then add a Message instance at the end of the file:
const message = new Message({
keys: ["BackgroundColor", "TextColor", "TemperatureUnit", "ShowDate", "HourFormat"],
onReadable() {
const msg = this.read();
const bg = msg.get("BackgroundColor");
if (bg !== undefined) {
settings.backgroundColor = { r: (bg >> 16) & 0xFF, g: (bg >> 8) & 0xFF, b: bg & 0xFF };
const tc = msg.get("TextColor");
if (tc !== undefined) {
settings.textColor = { r: (tc >> 16) & 0xFF, g: (tc >> 8) & 0xFF, b: tc & 0xFF };
const tu = msg.get("TemperatureUnit");
if (tu !== undefined) {
settings.useFahrenheit = tu === 1;
const sd = msg.get("ShowDate");
if (sd !== undefined) {
settings.showDate = sd === 1;
const hf = msg.get("HourFormat");
if (hf !== undefined) {
settings.use24Hour = hf === 1;
saveSettings();
updateColors();
drawScreen();
// Re-fetch weather if temperature unit changed
requestLocation();
The keys array tells Message which AppMessage keys to listen for - these
must match the messageKeys in package.json.
Clay sends colors as 0x00RRGGBB int32 values. We extract the red, green, and
blue components with bit shifts:
(value >> 16) & 0xFF(value >> 8) & 0xFFvalue & 0xFFToggles arrive as int32 values where 1 means on and 0 means off.
After updating the settings object, we save to localStorage, recreate the
Poco color values with updateColors(), and redraw the screen. If the
temperature unit changed, we also re-fetch weather so the API returns values
in the correct unit.
Click the play button to compile and install, then tap the gear icon in the emulator to open the settings page.
Build and install your watchface, then use pebble emu-app-config to open
the settings page in your browser:
$ pebble build && pebble install --emulator emery
$ pebble emu-app-config
Try changing the background color, text color, and toggling the date, temperature unit, and hour format - you should see the watchface update immediately.
| C (Clay) | Alloy (Clay + localStorage) | |
| Settings UI | Clay JSON config on phone | Same Clay JSON config on phone |
| Phone-side code | Clay init in PKJS | Clay init + proxy in PKJS |
| Receiving settings | inbox_received_callback with dict_find |
Message class with onReadable |
| Storage | persist_write_data() / persist_read_data() |
localStorage.setItem() / getItem() |
| Serialization | Raw struct bytes | JSON strings |
| New fields | Must call defaults before load | Spread operator merges defaults |
The phone-side Clay setup is identical between C and Alloy - the same
config.js works for both. The difference is on the watch side: C uses
dict_find in an inbox callback to extract values, while Alloy uses the
Message class with a readable callback.
Congratulations! You have built a complete, feature-rich Pebble watchface in Alloy. Here is everything it includes:
localStorage.In this final part we learned how to:
localStorage for persistent key-value storage.Message class.Check your code against the source for this part. Now it is time to publish your watchface and share it with the world!
