Index 01 is a small ring with a button and a microphone, sold at repebble.com/index. Press the button, say the thought you want to keep, and the recording is sent to your phone, where it is added to your notes, set as a reminder, or kept in the Index feed for later. The ring records only while the button is pressed. Speech recognition and the assistant can run on the phone with no internet connection, or in the cloud.
The ring sends each recording to the Pebble mobile app over Bluetooth, and the app transcribes it, acts on it, and keeps it in the Index feed. Developers can receive each recording at their own HTTP endpoint with a webhook, give the assistant new tools by connecting an MCP server, or write a plugin that the assistant can use.
The ring firmware is a small fixed loop: it detects button presses, records
audio while the button is held, holds recordings until the phone collects
them, and transfers them over Bluetooth. It does not transcribe or interpret
anything. All of the logic lives in the Pebble mobile app, which is open
source at
github.com/coredevices/mobileapp.
The ring code is in the experimental module of that repository. This section
documents the app side only; there is no ring firmware SDK.
The button recognises five gestures. Each one is routed from the Ring Button screen in the Index 01 settings of the Pebble mobile app. The three music gestures can be configured on Android only; on iOS they are shown disabled.
| Gesture | Options |
| Click, Double click, Triple click | Play/Pause, Next track, or Nothing |
| Hold & Talk | Index agent, Web search, MCP sandbox, Webhook only, or Nothing |
| Double click & hold | Index agent, Web search, MCP sandbox, Webhook only, or Nothing |
The two hold gestures record a voice note. Index agent transcribes the note and takes actions such as creating a note, a reminder, a timer, or a calendar event. Web search answers a question and puts the answer in the feed. MCP sandbox runs the recording through a sandbox group of MCP servers that you choose. Webhook only sends the recording to your endpoint and does nothing else. A recording gesture routed to Index agent, Web search or MCP sandbox can also send a copy to its webhook with the Also send to webhook switch; the switch is not shown for Webhook only or Nothing.
Speech recognition and the assistant model are each set to run in the cloud or on the phone in the Index 01 settings. Webhooks do not depend on either setting: the audio is sent as recorded, and the transcript is whatever the selected speech recognition produced. Remote MCP servers are only called by the cloud model.
There are four extension points.
create_note or create_reminder can
be offered as a destination for notes and reminders. Plugins are a preview
and are off by default.Everything in this section is implemented in the Pebble mobile app at github.com/coredevices/mobileapp:
external/indexwebhook/service/button/settings/mcp/mcp/client/
