Another popular feature added to a lot of watchfaces is a battery meter, enabling users to see the state of their Pebble's battery charge level at a glance. This is typically implemented as the classic 'battery icon' that fills up according to the current charge level, but some watchfaces favor the more minimal approach, which will be implemented here.
This section continues from Part 3, so be sure to re-use your code or start with that finished project.
The state of the battery is obtained using the BatteryStateService. This
service offers two modes of usage - 'peeking' at the current level, or
subscribing to events that take place when the battery state changes. The latter
approach will be adopted here. The battery level percentage will be stored in an
integer at the top of the file:
static int s_battery_level;
As with all the Event Services, to receive an event when new battery information
is available, a callback must be registered. Create this callback using the
signature of BatteryStateHandler, and use the provided
BatteryChargeState parameter to store the current charge percentage:
static void battery_callback(BatteryChargeState state) {
// Record the new battery level
s_battery_level = state.charge_percent;
To enable this function to be called when the battery level changes, subscribe
to updates in init():
// Register for battery level updates
battery_state_service_subscribe(battery_callback);
With the subscription in place, the UI can be created. This will take the form
of a Layer with a LayerUpdateProc that uses the battery level to draw a
thin, minimalist white meter along the top of the time display.
Create the LayerUpdateProc that will be used to draw the battery meter:
static void battery_update_proc(Layer *layer, GContext *ctx) {
Declare this new Layer at the top of the file:
static Layer *s_battery_layer;
Allocate the Layer in main_window_load(), assign it the LayerUpdateProc that will draw it, and
add it as a child of the main Window to make it visible:
// Create battery meter Layer
s_battery_layer = layer_create(GRect(14, 54, 115, 2));
layer_set_update_proc(s_battery_layer, battery_update_proc);
// Add to Window
layer_add_child(window_get_root_layer(window), s_battery_layer);
To ensure the battery meter is updated every time the charge level changes, mark
it 'dirty' (to ask the system to re-render it at the next opportunity) within
battery_callback():
// Update meter
layer_mark_dirty(s_battery_layer);
The final piece of the puzzle is the actual drawing of the battery meter, which
takes place within the LayerUpdateProc. The background of the meter is drawn
to 'paint over' the background image, before the width of the meter's 'bar' is
calculated using the current value as a percentage of the bar's total width
(114px).
The finished version of the update procedure is shown below:
GRect bounds = layer_get_bounds(layer);
// Find the width of the bar (total width = 114px)
int width = (s_battery_level * 114) / 100;
// Draw the background
graphics_context_set_fill_color(ctx, GColorBlack);
graphics_fill_rect(ctx, bounds, 0, GCornerNone);
// Draw the bar
graphics_context_set_fill_color(ctx, GColorWhite);
graphics_fill_rect(ctx, GRect(0, 0, width, bounds.size.h), 0, GCornerNone);
Lastly, as with the TickTimerService, the BatteryStateHandler can be
called manually in init() to display an inital value:
// Ensure battery level is displayed from the start
battery_callback(battery_state_service_peek());
Don't forget to free the memory used by the new battery meter:
layer_destroy(s_battery_layer);
With this new feature in place, the watchface will now display the watch's battery charge level in a minimalist fashion that integrates well with the existing design style.
In the next, and final, section of this tutorial, we'll use the Connection Service to notify the user when their Pebble smartwatch disconnects from their phone.
