Device Compatibility
Rocky.js requires Pebble OS v4.x and therefore will not support Pebble Classic or Pebble Steel.
In this tutorial we'll cover the basics of writing a simple watchface with Rocky.js, Pebble's JavaScript API. Rocky.js enables developers to create beautiful and feature-rich watchfaces with a modern programming language.
Rocky.js should not be confused with Pebble.js which also allowed developers to write applications in JavaScript. Unlike Pebble.js, Rocky.js runs natively on the watch and is now the only offically supported method for developing JavaScript applications for Pebble smartwatches.
We're going to start with some basics, then create a simple digital watchface and finally create an analog clock which looks just like this:
If you haven't already, head over the SDK Page to learn how to download and install the latest version of the Pebble Tool, and the latest SDK.
Once you've installed the Pebble Tool and SDK 4.0, you can create a new Rocky.js project with the following command:
$ pebble new-project --rocky helloworld
This will create a new folder called helloworld and populate it with the basic
structure required for a basic Rocky.js application.
Watchface are essentially long running applications that update the display at a regular interval (typically once a minute, or when specific events occur). By minimizing the frequency that the screen is updated, we help to conserve battery life on the watch.
The main entry point for the watchface is /src/rocky/index.js, so we'll
start by editing this file.
The very first thing we must do is include the Rocky.js library, which gives us access to the APIs we need to create a Pebble watchface.
var rocky = require('rocky');
Next, the invocation of rocky.on('minutechange', ...) registers a callback
method to the minutechange event - which is emitted every time the internal
clock's minute changes (and also when the handler is registered). Watchfaces
should invoke the requestDraw method as part of the minutechange event to
redraw the screen.
rocky.on('minutechange', function(event) {
rocky.requestDraw();
NOTE: Watchfaces that need to update more or less frequently can also register the
secondchange,hourchangeordaychangeevents.
Next we register a callback method to the draw event - which is emitted after
each call to rocky.requestDraw(). The event parameter passed into the
callback function includes a CanvasRenderingContext2D object, which is used
to determine the display characteristics and draw text or shapes on the display.
rocky.on('draw', function(event) {
// Get the CanvasRenderingContext2D object
var ctx = event.context;
The RockyDrawCallback is where we render the smartwatch display, using the
methods provided to us through the CanvasRenderingContext2D object.
NOTE: The
drawevent may also be emitted at other times, such as when the handler is first registered.
In order to create a simple digital watchface, we will need to do the following things:
minutechange event.draw event, so we can update the display.To create our minimal watchface which displays the current time, let's
replace the contents of /src/rocky/index.js with the following code:
// Clear the screen
ctx.clearRect(0, 0, ctx.canvas.clientWidth, ctx.canvas.clientHeight);
// Determine the width and height of the display
var w = ctx.canvas.unobstructedWidth;
var h = ctx.canvas.unobstructedHeight;
// Current date/time
var d = new Date();
// Set the text color
ctx.fillStyle = 'white';
// Center align the text
ctx.textAlign = 'center';
// Display the time, in the middle of the screen
ctx.fillText(d.toLocaleTimeString(), w / 2, h / 2, w);
// Display a message in the system logs
console.log("Another minute with your Pebble!");
// Request the screen to be redrawn on next pass
To compile the watchface, make sure you have saved your project files, then run the following command from the project's root directory:
$ pebble build
After a successful compilation you will see a message reading 'build' finished
successfully.
If there are any problems with your code, the compiler will tell you which lines contain an error, so you can fix them. See Troubleshooting and Debugging for further information.
Now install the watchapp and view the logs on the emulator by running:
$ pebble install --logs --emulator basalt
You should see a loading bar as the watchface is loaded, shortly followed by your watchface running in the emulator.
Your logs should also be displaying the message we told it to log with
console.log().
Note: You should prevent execution of the log statements by commenting the code, if you aren't using them. e.g.
//console.log();
In order to draw an analog watchface, we will need to do the following things:
minutechange event.draw event, so we can update the display.We're going to need to draw two lines, one representing the hour hand, and one representing the minute hand.
We need to implement a function to draw the hands, to prevent duplicating the
same drawing code for hours and minutes. We're going to use a series of
CanvasRenderingContext2D methods to accomplish the desired effect.
First we need to find the center point in our display:
// Determine the available width and height of the display
// Determine the center point of the display
var cx = w / 2;
var cy = h / 2;
Now we know the starting point for the hands (cx, cy), but we still need to
determine the end point. We can do this with a tiny bit of math:
var x2 = cx + Math.sin(angle) * length;
var y2 = cy - Math.cos(angle) * length;
Then we'll use the ctx parameter and configure the line width and color of
the hand.
// Configure how we want to draw the hand
ctx.lineWidth = 8;
ctx.strokeStyle = color;
Finally we draw the hand, starting from the center of the screen, drawing a straight line outwards.
// Begin drawing
ctx.beginPath();
// Move to the center point, then draw the line
ctx.moveTo(cx, cy);
ctx.lineTo(x2, y2);
// Stroke the line (output to display)
ctx.stroke();
function fractionToRadian(fraction) {
return fraction * 2 * Math.PI;
function drawHand(ctx, cx, cy, angle, length, color) {
// Find the end points
ctx.lineWidth = 8;
// Begin drawing
ctx.beginPath();
ctx.moveTo(cx, cy);
ctx.lineTo(x2, y2);
ctx.stroke();
var d = new Date();
// Clear the screen
// and the max size of watch hands
var cx = w / 2;
var cy = h / 2;
// -20 so we're inset 10px on each side
var maxLength = (Math.min(w, h) - 20) / 2;
// Calculate the minute hand angle
var minuteFraction = (d.getMinutes()) / 60;
var minuteAngle = fractionToRadian(minuteFraction);
// Draw the minute hand
drawHand(ctx, cx, cy, minuteAngle, maxLength, "white");
// Calculate the hour hand angle
var hourFraction = (d.getHours() % 12 + minuteFraction) / 12;
var hourAngle = fractionToRadian(hourFraction);
// Draw the hour hand
drawHand(ctx, cx, cy, hourAngle, maxLength * 0.6, "lightblue");
Now compile and run your project in the emulator to see the results!
If your build didn't work, you'll see the error message: Build Failed. Let's
take a look at some of the common types of errors:
As part of the build process, your Rocky index.js file is automatically
checked for errors using a process called
'linting'.
The first thing to check is the 'Lint Results' section of the build output.
========== Lint Results: index.js ==========
src/rocky/index.js(7,39): error TS1005: ',' expected.
src/rocky/index.js(9,8): error TS1005: ':' expected.
src/rocky/index.js(9,37): error TS1005: ',' expected.
src/rocky/index.js(7,1): warning TS2346: Supplied parameters do not match any signature of call target.
src/rocky/index.js(7,24): warning TS2304: Cannot find name 'funtion'.
Errors: 3, Warnings: 2
Please fix the issues marked with 'error' above.
In the error messages above, we see the filename which contains the error, followed by the line number and column number where the error occurs. For example:
Filename: src/rocky/index.js
Line number: 7
Character: 24
Description: Cannot find name 'funtion'.
rocky.on('minutechange', funtion(event) {
As we can see, this error relates to a typo, 'funtion' should be 'function'.
Once this error has been fixed and you run pebble build again, you should
see:
Everything looks AWESOME!
So what do we do when the build is successful, but our code isn't functioning as expected? Logging!
Scatter a breadcrumb trail through your application code, that you can follow as your application is running. This will help to narrow down the location of the problem.
console.log('minutechange fired!');
Once you've added your logging statements, rebuild the application and view the logs:
$ pebble build && pebble install --emulator basalt --logs
If you find that one of your logging statements hasn't appeared in the log output, it probably means there is an issue in the preceding code.
If you've tried the steps above and you're still having problems, there are plenty of places to get help. You can post your question and code on the Pebble Forums or join our Discord Server and ask for assistance.
So there we have it, the basic process required to create a brand new Pebble watchface using JavaScript! To do this we:
'rocky' library.minutechange event.draw event.If you have problems with your code, check it against the sample source code provided using the button below.
If you successfully built and run your application, you should have seen a very
basic watchface that closely mimics the built-in TicToc. In the next tutorial,
we'll use postMessage to pass information to the mobile device, and
request weather data from the web.
